1st post here. 2 questions. 1. is there a large difference between 5w20 semi-synthetic and 5w50 full synthetic? 2. What about the 5.0 would cause engine ticking (actually sounds like noise made when engine/exhaust cooling off after engine shut down) noise after synthetic put in?
5w20 and 5w50 synthetic used in two different engines both causing intermittent noise after synthetic put in.
