JHZR2
Staff member
Hi,
I have an oil tank in my basement. The house has had gas heat for the last 30 years, but it is an old original.
Im going to have a new furnace/indirect water heater installed, however due to some of the incentives, in order tot ake advantage the oil tank needs to go out. I look at it as freeing up space for free and being susidized by the incentives... not too bad.
But one thing I could do is DIY. It is in my basement in an area where the basement was only half dug out, so I have a full, walk-around basement, but one section is only half as deep.
I have a good milwaukee sawzall. I'd need to cut it up into small parts essentially on my knees. Can an oil tank be cut up with a sawzall without severe issues getting it done? Would this be a reasonable DIY or am I kidding myself?
Thanks!
Thanks!
