Originally Posted By: subiedriver
With the oil cold, first thing in the morning, the oil is up to the hot notch. That should be about 1/2 quart over full. I'll drop and drain the filter this weekend, just to be safe.
Its running fine, no smoke, burning smell, ect, no funny sounds.
Check it HOT not cold.
If it is below the hot notch when ran for a bit you will be fine. Don't worry so much...
