Originally Posted By: Anies
Originally Posted By: HK_Ace
Oh no, I hope she was at least using a good synthetic. Check the dipstick and oil-filler cap for varnish. You may use an oil that does a good job of cleaning the engine- one of the Pennzoils- like the Ultra. This would be a very interesting UOA to Blackstone...I'd do that too.
You never want to use a synthetic with a rotary engine from Mazda. It actually has to burn oil so it can lubricate the Apex seals in the engine. Synthetic is more resistance to burn off and there for causes a very high failure rate in their motors. Conventional or Mazda's specifically engineered blend can be used.
IIRC, Mazda itself backed away from the "no syn" directive a good number of years ago. I doubt that they'd be selling this if they hadn't. Note the language on the can (FULL synthetic for the Renesis (rotary) engine).
Originally Posted By: aquariuscsm
How about this stuff?
