Originally Posted By: Gary Allan
I wasn't trying to be confusing. I just reworded what you said about the lifetime of an ADBV for a certain OCI, where nitrile won't be as effective for as long as silicone. I think that's what I was saying, since confusing you now caused me to be confused.
Quote:
The CFL1 was a specified filter for the 300 at the time, and was made. The CFL1 didn't make it much past the middle to late eighties, if I recall correctly.
Purolator was the only one out of all the usual suspects to actually have a xref for the number. Fram never heard of it.
That doesn't surprise me. Purolator probably made it at the time. The last time I could buy a CFL1 was, like I said, back in the late 1980s. It was speced for 2.3L, 4.9L, 5.0L and so forth, alongside the FL1A. CFL1 was the standard choice, Fl1A the upscale version.
I really tend to think this is "at one time". I can't see this filter being viable beyond the later 60's, but that's just me. Ford has marketed a number of upgrades on the FL1A. There was a heavy duty version (something like FL1AXHD or XDFL1A) and the racing filter ..which apparently wasn't like most racing filters. It was actually a better filter and not a sieve.
Quite correct. It was only at one time. It obviously wasn't viable or it wouldn't have been discontinued. There weren't upgrades to the FL1A back then. FL1A was simply marketed as a long life filter and also had the ADBV. I believe they also said there was improved media, but I can't recall for sure.
I find this odd. There is no other purpose for this filter to be produced. I don't think there's (with the exception of one or two CASE references) one domestic application for it.
There are a few more that are all specific to Euro engines. Why in the heck would Wix waste the material where the Teutonic's gave up an opportunity to complicate something?
I agree with you. It is odd. As you pointed out, the Wix version does have the silicone ADBV. I've used the filter myself and have seen the ADBV, too.
The North American Bosch has the ADBV, the German one does not, nor do the Mahle or Mann versions. They have thread end bypass valves, and that's it - no ADBV. All I've ever used on the Audi are Wix, Bosch (American and German), Mahle, and Mann. The only ones to have the ADBV were American Bosch and Wix. I thought it was weird, too.
Is it Wix's standard manufacturing procedure to use a silicone ADBV, perhaps? Maybe they just put one in each filter as a matter of course. As for German complication or over-engineering, perhaps they got their fix with the bypass valves. They look like they could deflect a bullet.
