Originally Posted By: hostile
Do a double coat of Collinite: one coat of 476s followed up with their 845.
That should last nearly all year.
What advantage is topping the 476s with the 845? Wouldn't 2 coats of the 476s do a nice job?
845 gives a deeper, "wetter" look.
I talked to a rep at Collinite (Steve was his name, iirc), and he said that the 476 acts more as more of a sealant and if you are going to use the 476/845 in conjunction, that is the best (rather than 845/476).
Apply the 476, wait 24 hours, then apply the 845.
With that double coat, bullets will most likely bounce off of the car.
