2008, 3.7L 3.05 rear, 5spd wa580 trans. 25000 miles.
stock mopar (valvoline?) atf+4
stock mopar 75-140 syn gear lube.
swapped in 6 qts of Castrol ATF+4. wanted to use amsoil but it's got the lifetime powertrain warranty so I stayed in spec. Castrol had the closest vi and pour points to amsoil that I saw. oem fluid came out red-brown through the suction hose, looked DARK in the jug, didn't smell burnt (I drive it pretty easy) but smelled very dull compared to that normal atf sharpness.
swapped rear to M1 75-140 syn. oem came out yellow-gray, in the hose, grey in the jug.
trans used to be sluggish into reverse. delay is now much shorter. 1-2 shift is snappier.
Car "feels" different... can't describe how. kids in back said it was quieter.
the BEST avg mpg I could achieve since new was 22.5 on my commute, really trying. I hit 24.0 last week, really trying.
Hwy mpg with air was 21 mpg, now 22, round trip total.
yay!
yay!
