I don't like the term "cupping" because it is soooooo misused.
In the old, bias tire, days, "cupping" actually looked like a "cup" had scooped out some of the tread. That was caused by imbalance or a bad shock - and in those days, that was pretty common.
But today's radial tires don't show a single "cup" from the same cause. Plus, shocks and tires have gotten better and this isn't as much of a problem as it used to be.
I'm of the opinion that mis-alignment is now the leading cause of "irregular wear" (the term I prefer). Plus I do not think most folks are sophisticated enough to be able to tell the difference between alignment based irregular wear and the wear caused by a bad shock.
So now to the question at hand.
First, it is possible to generate irregular wear without any tread pattern whatsoever. This seems to be related to higher order vibration harmonics.
Those harmonics seem to be a function of the tire size (its physical dimensions), the uniformity of tha casing (which is somewhat related to the consisitency of the manufacturing process), and a lot to do with the tread pattern (which is somewhat related to manufacturing consistency, but mostly related to the design of the pattern itself).
Needless to say, straight ribbed tread patterns are pretty much immune to this - but you won't find any of those. Even the mildest of tread patterns has a shoulder pattern that includes some "lugs" in oder to qualify as "all season" - and those lugs get subjected to those vibrational harmonics.
My pet theory: Tread patterns where the pattern is more broken up, especially if the pattern forms a 45º angle across the face of the tread, will be more suseptible to irregular wear. Tread patterns with more "luggy" shoulders are more suseptible.
Frankly, I don't think the brand plays much of a role except to say that some manufacturers tend to use tread patterns that are more suseptible.
But there are several complicating factors making it very difficult to sort this all out.
