there are contacts inside the motor that have a separate power lead. motor gets ground, ign power and switched power. the steady ign power is what powers them back the cowl even if the switch is off. these contacts have failed in the motor. if you disassemble, bitog-style, you may find a physical obstruction that can be removed, bent, or you can snip the wire that's always hot when the key is on.
M
