I think you'll be just fine! If the center hub of the wheel on the Honda rim will fit over the center hub of the Sentra and they are both 4 lug design wheels, I beleive you'll be fine. I once put wheels from a Dodge onto a Honda and it fit perfectly but, the Honda wheels didn't fit the Dodge because the center hole on the Honda wheels were too small althought the lugs were fine. I bored the centers to fit the Dodge. There are many wheels from one MFG that will fit the others with the exception of the center hub. If you were to purchace a universal wheel for most small cars', the center hub hole would be at the lagrest size the that wheel would need to fit(with the proper lug nut spacing) wheather it be a 4 or 5 lug design.
Just trying something recently between my 04 Altima(5 lug wheels) and my daughters 06 Mazda3(5 lug wheels). I wanted to put on my Nissan factory wheels on her car just to see it really is her tires making the noise(I susspect tire noise or front wheel bearings). The Nissan wheels wouldn't fit over the hub(s) of the Mazda but everything else would have been fine.
