This is the latest oil sample of 15w40 (ignore the sheet, as they still have 10w30 from the last sample of the 10w30 breakin oil). This tractor gets started almost every day in the winter to run for about 45 minutes, so as you can imagine, those are some hard hours on this oil. This is also the tractor that I installed the by-pass filter on. I plan on changing the oil at around 225 to 250. I will probably go on and change all the filters. Hopefully as the engine breaks in more (by around 300-400 hours) the metal numbers will continue to fall. The copper is most likely from the copper tubing for the bypass filter that I am using, as this was the first oil change with this filter set up, so the copper tubing was fresh for this sample. Do you think I should go with Delvac 1300, Delo 400, Rotella T3, Rotella T5, or Rotella T6? If I go Rotella T6, I would need a good reason to spend that much more money. The tractor gets about 250-300 hours of use a year, a lot of that being start and stop in the winter, where it may not get past 170 degrees.
Link in case it's too small to see on here:
http://i43.photobucket.com/albums/e386/laxattax89/Rotella15w40Allis230hoursonOH200onoil.jpg
Hurst
Hurst
