I got my tractor up on a ramp about 30-40 degrees (front end). I could only suck out one qt of the 2 litre capacity. Then only air came out. So I sucked what could be sucked out completely. I went through the vent-cap in the rear of the unit and replaced the cap with a new one. Wjen re-filling (with ASE Amsoil) it took exactly one qt to top off.
I just can't understand why the rest did not flow downhill and drain out too. It's almost as if the front oil compartment is isolated from the back.
Now this is easy to do...about an hour...a qt is better than nothing..but I did want to get it all with out pulling the trans completely off.
What's the deal?
What's the deal?
