The valvetrain is visible through the oil filler cap on most cars. All that is needed is a flashlight. Varnish, sludge, and the color of camshaft lobes are all mostly within sight. I bought a car about 6 months ago with no maintenance record. Upon replacing the timing belt, I had the pleasure of seeing a golden, metallic hue. The lobes were silver and the valve cover clean of any varnish whatsoever. The thing is, I've seen other valvetrains of the identical engine. Owners claim rigorous OCIs, but the insides has a dark brown layer of varnish.
Can a quick treatment of engine cleaner mask a dirty past? Does cleanliness just indicate the use of synthetics but not proper OCIs? I'd like to know more, since I will be buying another used car in my future. Can filler cap sight be used to gauge oil maintenance?
