I just rebuilt the inner and outer rockers on a 2000 GTP.
When I say repair I mean with new inners and outers, cut the old ones out and weld the new ones in approx 5 inches into the rear quarter.
This is a big and difficult job, definitely not for beginners.
To remove the plastic side skirts there are a few precautions that must be observed, the clips that go into the rear quarter panel and front fender must be preserved as they are not
Replaceable with any stock clips, if one gets broken a different fastener can be mickey moused.
Remove the front wheels and the 2 lower inner fender well screws
Remove the 2 screws holding the skirt on
Reach inside the fender and with pliers squeeze the clip while pulling the upper
part of the skirt outward (it has double sided tape, it may need a good pull, do not remove the skirt yet.
Remove the rear wheel and remove the 2 screws holding the skirt.
Pull the top of the skirt gently away from the rear quarter very slightly; it also uses double sided tape.
Carefully use a razor blade to cut through the tape without pulling, use needle nose pliers to squeeze the clip to remove it.
Pull the skirt from the middle upper and lower out of the metal channel.
Some points about these skirts. The metal channel often rusts badly and is not available alone. The whole skirt must be purchased approx $450, they are scarce even used.
The replacement rockers do not come with studs for the channels and must be welded onto the new rockers..
The rockers rust out worse on cars with sunroof because GM put the sunroof drains
inside the rocker panels. Sunroof equipped cars most often need both the inner and outer rockers. I reroute the drains by extending the original tubes with ¼” nylon tubing to the
rear of the car through the trunk floor exiting just in front of the bumper.
To repair the rockers the rear interior must be removed, there is a large foam panel impregnated with wire mesh that must be removed to get into the rocker area from inside.
I have one here now that is finished except for paint and putting the interior back in if you need pics.
