Originally Posted By: StevieC
Where do I get the "ssh" meta package?
I will definitely do the SFTP instead.
And thanks kindly for your detailed description!
Once your system is set up, in a terminal (as root) simply run (without quotes) "aptitude install ssh". The magical aptitude program will grab everything you need and set the system up to start the SSH service at boot time. Alternatively, you can use Synaptic, which is a GUI program for software management.
EDIT: Synaptic will only be installed if you ALSO check "Desktop environment" at that stage of the install as well. If you do not install a "Desktop environment" there will be no GUI programs installed at all.
SSH is already included in the Debian repositories, it just isn't installed by default.
Once SSH is installed, you log into your machine with your user credentials (NEVER AS ROOT!) so make your user's password for this machine absurdly obfuscated, too!
