Oil filter for a 25HP Kohler?
I looked and found the following equivalents:
Fleetguard LF3335
Purolator L10241
Wix 51348
Here are the Wix Specs:
Part Number: 51348
UPC Number: 765809513488
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameter (attached)
O.D. 2.734
I.D. 2.430
fwiw i use a supertech 3614 and it is a direct replacement for the longer kohler filter
That's funny...the same filter used on about every make of car manufacturer too! At least it should always be supported.
I ran one size on my Command 20; Motorcraft FL400 or the Napa, Carquest and Supertech equivalent. Currently have a ST3600 on my Kohler Courage 20 twin. Same basic block dimensions as the Command. You do not have to worry about exotic or hard to find sizes for these engines. FL400/ST3600 is all you need and is the largest, safe/comfortable fit.
Joel
