First, let's define "better" as: better at ROAD-HOLDING.
and, also bad roads are regular normal paved roads in the USA that have a significant percentage of cracks, bumps, or little potholes (little potholes are the ones you drive through and not around.)
After much reading and just pondering the physics of it, I would guess that on bad roads--softer is better.
Here's why I think so: When you hit a bump, the tires & suspension absorbs much of the bump, the springs compress (with the help of dampers). The driver and the rest of the car (the sprung weight) will also feel a bit of it but most of it is already absorbed. The shock is absorbed, the tires maintain contact with the road.
Now, let's consider a scenario where the car has a very stiff suspension. When you hit a bump, a much stiffer suspension is no real suspension at all. The entire vehicle absorbs the shock and that vertical motion causes the car to lose contact with the road.
This is a subject that I have given much thought about for a long time. Obviously, the answer is to do a semi-scientific test: that is, to adjust the suspension of the car and just take a ride myself. I, unfortunately, cannot afford such a luxury.
Pondering about it and asking others to chime in is the best I can do.
SO, what do you think of my analysis. Would you say that stiffer is definitely not better for poor roads?
