Post your latest small engine oil change
SEARS Eager 1 Tecumseh: NAPA 30W
I had a friend that worked for John Deere repairing mowers. He said that you would be sick if you knew how many homeowners never change their lawnmower oil. That was the majority of their engine problems.
ETQ 2250 generator with 4 h.p. chonda engine 1/2 quart amsoil ase 10w30/sae30, ngk bpr6es spark plug, at 20 hours.
1992 Toro Recycler 5HP.
10-30 Trop Artic Semi-Syn & MMO.
Runs great!
new WEEDEATER with 5 H.P. Briggs + Stratton : 15 ounces of leftover PLATINUM 5w-30 and 2 ounces PLATINUM 10w-30 .
You have a 5Hp weed wacker??
After reading a lot of this thread, I decided to do a lawn mower OCI. It's just a cheap Murray mower - 20" cut with B&S 3.5 HP motor. I put in fresh Castrol 10-30.
Was talking to a guy at a local muffler shop about how many people at BITOG use 10-30,. etc.,m in their lawn mower motors, and he said "you should NEVER use 10-30 in a mower motor, period, and when I told him I've learned a lot of good things at BITOG, he looked angry, so I didn't press the issue. After the leftover GTX 10-30 and 10-40 is used up, I'll put Rotella 15-40 in it.
He probably is referring to a Weedeater brand lawn mower.
yes .
BOLENS riding lawn mower with BRIGGS and STRATTON 13.5 H.P.engine : about 44 ounces of PLATINUM 10w-30 .
Generac Home Standby Generator: Model 04390-2 (15 KWH - LP /13 KWH - NG)
Engine : Briggs & Stratton GT-990 (2 Cylinder)
Oil Filter: Generac 070185E Extended Life Oil Filter
Oil: 2 Quarts Castrol Syntec European Formula 0W-30
Wow! 7665 views and only 115 oil change replies? That's only a reply rate of 1.5%. Someone's not changing their oil!
1 year old Birggs 20 HP V-Twin
Change oil every 25 hrs or 2x / season
Use the Briggs Yellow 2x filter
German Castrol "gold stuff" 0W-30
Runs great!
