I found some info on some web sites about running a 180F(82C) thermostat in a 22R Toyota engine that can cure pinging problems especially in warmer climates.They say the stock thermostat is a 195F(90C).
Also there was a tip of drilling a 1/8 inch hole in the disc part of the thermostat?
My 22R pings under load and gets worse the warmer the weather?
It has been checked out by mechanics and has been given the all clear.
Has anyone got any experince with running a lower temp thermostat in a 22R?
