If it's RWD how are you going to lock the front wheels?
I know the rams have a dip/divot the wheels will sit in, but I would personally be a bit nervous with the rear on "tippy" jackstands without the other axle secured.
I suspect the most dangerous part of this would be the transition time, getting it up, and once it's up it'll be sturdy.
If it's RWD with a solid axle, and you jack on the pumpkin and put saddle type stands on the outboard parts of the axle, that would probably sit pretty okay.
Even a FWD a/t in Park on ramps would make me nervous without positive retention of the rear tires, only need one tire to lose traction or find slop in the parking pawl and bump it over the little stop...
