Originally Posted By: rszappa1
If you were cleaning out a TB would you use this or the spray in a can????
I yank the TB off, remove IAC, Tps etc then spray in, let sit. Then wipe off and use some chlorinated brake cleaner to finish.
Throw back on. Can do this in about 15 minutes.
Can also spray down the TB Throat and leave on car but it wont get into the inner passage for the IAC
