Hello! I am new to the BITOG forum. I own a 2001 Acura CL (non-Type-S) and live in the Twin Cities, MN. My parents bought this car off the showroom floor back in 2001 and I bought it from them about two years ago. My car has about 210,000 miles. I obviously do a lot of driving (both city and highway) and typically get from point A to point B as fast as possible
I just acquired a second job that will require me to drive all around MN. My transmission was replaced at about 130K miles. For my performance modifications I have an AEM V2 Air Induction System, custom exhaust system, and custom aluminum radiator.
I am in need of an oil change. I already bought a K&N Performance Gold Wrench-Off Oil Filter and am wondering what oil I should use. My owner's manual states the following: "It is highly recommended that you use Genuine Honda Motor Oil in your vehicle for as long as you own it. A fuel-efficient oil is recommended for your Acura. Always use an oil that is labeled API Service SJ. Make sure it says For Gasoline Engines. An oil with a viscosity of 5W-30 is preferred for improved fuel economy and year-round protection in your Acura. You may use a synthetic motor oil if it meets the same requirements given for conventional motor oil: energy conserving, a service classification of SJ, and a viscosity of 5W-30. Your Acura does not need any oil additives. For normal driving conditions, change oil every 7,500 miles. For severe driving conditions, change oil every 3,750 miles."
My parents used conventional motor oil when they owned the car. I started using synthetic oil when I bought it. I used Pennzoil Platinum 5W-30 Full Synthetic Oil for my last oil change. I also hear good things about Mobil 1, Royal Purple, Castrol, and Red Line. What oil do you recommend I use for this next oil change?
