I just bought this truck. I can't change the oil myself due to health, so I've been researching on here. (thanks for the info so far!) The OM calls for a 5000 mile OCI, and gives you a choice of 0w20 or 5w20 for the same temp range. I live in VA, so fairly hot in the summer (90's) and about 20's for the coldest in the winter, with a few exeptions of course, so the 5w20 will work just fine.
I drive mostly rural, and around a small town and almost no highway, and I generally baby it. I'm going to stay with the 5k OCI, so probably stick with dino. Remember, this is an all aluminum engine. (fast as h*#L too!)
I only have about 2 choices, and this truck takes 7.5 quarts per change. You even have to drop the skid plate to change the oil!
1st choice is a shop that will use Honda 5w20 oil, and a Toyota filter, and will charge $50. I've read that the Honda 5w20 is good oil, but who makes it? (been using it in my Honda van for 70k miles, hope it's good)
2nd choice. Another shop will let me bring my own, and will charge $20 to do the work. I've narrowed that down to 5w20 PYB or QS at Walmart with a Pure 1 or Toyota filter. (it uses a canister filter. What were they thinking!) By the time I add everything up, not even including my gas running to 2 different places for oil and filter, it is only about 5-6 dollars more expensive at the shop with the Honda oil.
So, since I need this truck to last "forever" is any of these oils preferable for a 5k OCI on this engine? And again, who makes the Honda 5w20? Thanks for any help!
