I drive my car mostly on the street, but take it up into the canyons as much as possible. I do put serious heat into the brakes, so much so in fact that even the rear brakes get hot enough to melt off Centric's E-coating.
I have flushed the system with brand new hi-performance brake fluid (Wilwood Hi-Temp 570) and am planning to get some new pads and rotors. I've got the rotors squared away, bu am still searching for the right pad.
Which of the two would be best for my situation?
Are there any others that you would suggest?
