Our 25HP Kohler command pro started consuming small amounts of oil at around 80 hours. It started to smoke when started. By 200 hours is was smoking very heavily when started and for the first few minutes after and used even more oil. Took it in and the engine had bad rings on one side. Kohler authorized the dealer (fantastic dealer with great mechanics) to rebuild the engine with new rings on both sides, new reed valves, complete gasket set and new spark plugs. Unit now has over 700 hours on it and it NEVER smokes at any time. It also uses absolutely no oil.
