Originally Posted By: Gary Allan
I thought you used KY jelly on your shaft
Is Lucas an upgrade?
Gary, the stuff that you were referring to is obstetrics lube, which I have brought in in 20 litre pails.
Helps stick plastic sheeting to the tubes when looking for condenser leaks.
