Originally Posted By: JTK
kcfx4, in your ~35yrs of OPE dealership experience, have you seen engine failures on maintained engines that were using viscosity ranges other than what was recommended by the engine manufacturer? For instance; 15w40 or 20w50?
Joel, no i have not. My point was, what the OEM recommends, that turned into how to read a manual, which turned into, which manual to read. Just as a Ford has 5w20 written on its oil filler. If briggs had that (or knew for sure the engine were mounted on a mower) it would say sae30, just as it does in the manual.
