You shouldn't be getting an update every day, or even every week. It may be that an update failed to install properly and it keeps trying. If it becomes an annoyance, try removing Java from add/remove programs, then reinstall the latest version from Java.com. This should take care of the problem. Java DOES check to see if an update is available every day though, though it shouldn't be triggering UAC unless it is actually updating something.
