Originally Posted By: JAG
Originally Posted By: esteve
On the drive home, I was very surprised at the high oil temps, around 240-250 degrees! Does anybody know how much cooler the oil generally runs with the factory oil cooler? You can just feel the heat radiated by these motors with the windowns down or standing outside while the car's running.
In the summer during normal driving the oil temp. in my 135i (w/ oil cooler) usually settles at 230-240 degrees. I have seen 245-250F but that was during a traffic jam in high ambient temps. Low airflow in traffic jams doesn't allow the oil cooler to help much.
Rotella-T 5W-40 is probably better to use in this engine than many other oils that do not meet BMW LL-01. I'm sticking with oil change intervals less than 4K since I'm using up a stash of Mobil 1 5W-40 Turbo Diesel Truck and I'm afraid that longer OCIs would lead to engine and PCV deposits.
I agree with JAG ^^. I basically do the same on my Direct Injected Turbo car. I'd run Redline 10w40 before I'd run the RLI stuff. saaber has some really great UOA's done with the Redline 5w40 on his D.I. Turbo. I'm running Rotella T6 right now but my plan is to get some Redline 10w40 in, hoping it will help with the intake valves build-up issues known with our cars, since it's a ester based oil.
On the cheap I'd go with the Rotella T6 though.
