I pretty much decided on biting the bullet and getting a code scanner I narrowed it down to these two Equus 3160 vs 3140.
The 3160 can diagnose ABS codes.
The 3140 can also work on engines prior to 1996. It also says it can do this. This device not only scans your vehicle, it also allows you to freeze-frame live timing and pinpoint your vehicle's problem. Instead of having to recreate a scenario over and over again, you can now playback the timing to scrutinize all the data and make a clear diagnosis.
Which of the two is the better choice for 1996 and newer?
