I've been told by a few people that on modern cars with ceramic brake pads, there's really no benefit to using drilled or slotted rotors any more. The reasoning is that ceramic pads don't outgas or dust up like semi-metallic or organic pads did, so the slots/holes aren't removing any gases or dust that prevent full contact with the disc surface.
If that was the case, then I would think with ceramic rotors, they would just serve to reduce the disc surface area and total braking capacity. Anybody have any definitive sources on this?
I was just wondering if it would be worth replacing the vented, flat-surface rotors on my SUV with drilled or slotted rotors to get a little better braking performance while towing a trailer. But then I was told that my Honda Pilot has ceramic pads, so I shouldn't do that.
