Originally Posted By: mechanicx
We been through this before. Typically psid with cold oil from the tests we have actually seen are in the 20-30 psid region tops, not 80 psid. 80 psid is a lot of pressure that few BBC pumps would put out. As superbusa points outs not a lot of flow is likely to be happening with cold oil while the oil pump hits pressure relief. So for 80 psid, the filter had to flow basically 0 oil despite over 80 psi of head pressure. I'm not saying it's not possible I'm just saying it's not a given.
+1 ... and to add, I think the only way the filter could have seen a 70~80 PSID "spike" is if the engine was at idle and then basically hit redline in a spit second. The RPM condition you might see at the drag strip.
When I'm at the drag strip, cars sit for a long time in the staging lane and I highly doubt the oil if at full operating temperature. Then they roll up and do a redline burnout, and then take off from the line. So there are instances of near instant pressure build-up on the inlet side of the filter. This could potentially cause a high PSID spike because the thicker oil can't instantly move in reaction to the positive displacement pump building pressure. Also, the pressure relief valve may lag some and this might cause a pump supply pressure higher than the bypass valve setting.
Put both of those factors on top of each other and you might see a second or two of near pump pressure PSID on the element.
The guy did not have an oil filter failure until he used ecore for the first time.
That's ins testing ... so if that's the case, other non-Ecore style filters were put under the same conditions, but survived.
I might email Purolator and ask them what the max PSID their filters can withstand. Someone should email Champ Labs and ask them what the max PSID their Ecores can take. If it's only 70 or 80 PSID, I'd consider that an under design issue as many engines may be able to cause a high PSID spike in the oil filter as I've described above.
