Run the blower motor and headlights, are they faster and brighter than normal? Blower motor is a great tool as the varying pitch can easily be picked up by your ears.
You should be getting ABS, AIRBAG, and CEL lights if your system voltage is really that screwy. Alt MIGHT be BCM controlled.
