Good grief. I feel compelled to leave a succinct (Haw!) post that the masses can actually use.
1. The goal of the thermostat is to "turn on" the heat exchanger (radiator) to reject excess heat energy from the engine into the atmosphere. "excess" means that the continued operation of the engine will cause block and head temps to go too high.
2. The thermostat regulates coolant temperature (rejects "excess" heat energy) by regulating flow to the heat exchanger (radiator) as a function of coolant temperature. i.e. higher temperature coolant on top of the engine will correspond to higher flow rate through the thermostat, to a limit defined by the water pump performance.
3. A heat exchanger is so-called because if it is brought into contact with a fluid that is colder than itself, it will cool as the fluid warms. If there is no temperature difference between the heat exchanger and the fluid, no energy transfer (heat rejection) takes place. A car's radiator, heater core, oil cooler, engine block (including heads, IM), ATF cooler, are all heat exchangers.
4. When the thermostat opens, it lets hot coolant into the radiator. Now that the radiator is hotter than the air around it, it begins to reject heat into the air. Heat transfer occurs.
5. The rate of heat rejection increases as the temparature differential between the working fluids (in this case, coolant and air) increases. Always. But the resistance to the heat transfer varies, and can limit heat transfer rates. For instance, radiators are usually painted black because the emissivity of the black surface is higher than for a polished metal surface, and more heat energy can be transferred FOR A GIVEN TEMPERATURE DIFFERENTIAL.
6. Rate of heat transfer is limited by flow rates and specific heat capacities. A kilo of water will only gain so much heat energy for a given temperature change.
7. Surfactant products such as water wetter increase the real-life maximum cooling capacity of your car's cooling system by improving the efficiency of heat transfer (point 5, above) from the engine block to the coolant and from the coolant to the metal in the radiator.
Note: You can safely increase the cooling capacity of your car's cooling system by simply increasing the proportion of water in the system. For example, going from 50/50 to 70/30 water/propylene glycol will give your system ~15% more cooling capacity with NO other changes. This is becasue water has a higher specific heat capacity than propylene or ethylene glycol. Physics, baby. Beautiful.
Best
Kaboomba
Best
Kaboomba
