The car 2004 Infiniti G35 5-speed Automatic Without the LSD. There is about ~61k miles on the car.
At highway speeds 50 mph and higher, there is a vibration in the rear. All of the tires are balanced so that is not the issue. After a drive one of the rear wheels seems to also be warmer than the rear.
I'm thinking maybe a frozen rear caliper. I'll jack the car up in neutral and see if the wheel spins freely. If not what is another culprit, rear wheel bearings, differential?
Btw, the car has Amsoil full synthetic severe gear in the rear end for the last 25k miles or so since it has been replaced. Transmission service is also performed periodically by us with Matic-J OEM fluid via drain and refill.
***The vehicle is Rear wheel drive for those that do not know.
