Hello folks,
I have a question about the transfer case in my '05 Dodge Durango. The case is an NV244 which is full time awd but it as has a selectable hi/lo range like a traditional 4x4. The AWD isn't a clutch type system, it works more like a rear end and divides power via a gearset.
The manual calls for regular ATF+4 like the transmission. I changed it last weekend but used Mobil 1 multi vehicle ATF instead. I figured Dodge just called for the ATF +4 just to simplify things since it was already using it in the transmission. I don't think the transfer case is particularly sensitive to type of fluid the way a transmission may be. My understanding is that the fluid is just providing a lubrication bath as opposed to the a hydraulic pressure it is subject to in the transmission.
Of course, now I am second guessing myself. Comments anyone?
