just recieved results and i thought i would share
07 6.0 94,632 mi. 4,879 mi. on sample
john deere plus 50 10w-30 CI-4
of the 4,879 mi., about 1,600 mi. were towing
iron...............9
chromium.......... nickel.............2
aluminum...........4
lead...............3
copper.............1
tin................3
silver........... titainium......... silicon............5
boron............178
sodium.............2
potassium........ molybdenum.......118
phosphorus......1315
zinc............1550
calcium.........3813
barium........... magnesium.........23
antimony......... vanadium.......... fuel% vol......... t/s% vol......... water% vol....... vis cs 100`c....10.8
i did not change at time of sample, this is my first run of 10w-30 and wanted to see if i could run to 7,500mi. as i have done with the plus 50 15w-40. i am impressed to say the least with the performance of the 10w-30 CI-4, my local dealer has around 150 cases, so after this sample i went over and lightened up their stock a little @ $11 a gallon.
according to deere specs this oil new is 11.7 vis, so it appears to have sheared a little, but still well within 30w spec
