I have a snowblower gearcase that is spec'd for Lubriplate GR132, what would a compatable grease I could use. I have a tube of Mobil 1 chassis grease, could I use it?
Lubriplate says it is a lithium complex NLGI No. 1 grease.
I'm guessing your Mobil chassis grease is a NLGI No. 2, which would make it too heavy for the snowblower application. That's not to say it wouldn't work, but it is heavier than what is specified.
Originally Posted By: Tempest
#1 can be hard to find locally. I know Amsoil sells #1 versions of many of their greases. The general purpose I think should do well.
So far I haven't been able to find #1 on the shelf anywhere in my area.
Check an industrial hardware store or an autoparts store that sells to industrial and construction customers. Especially in Michigan you should find some that need #1 consistency grease in the winter or in refrigeration equipment.
You might also check with a local power tool repair shop and ask if they'll sell you enough to do your job.
