I could be wrong, very wrong, but my thought is that using an oil with extra seal swellers may shorter the life of healthy seals over time. If i had leaks, i would use it, but with no leaks, i'm very hesitant.
I think your wrong....the idea of useing a HM oil is to get those seals back to what they were when the vehicle was near new. Even so-called healthy seals are not the same as they were when the engine was new.
It might be to late to use it once you have leaks, so why not be safe and not sorry......
__________________________________________
2003 Ford Focus SE 2.3L / 82K
Valvoline MaxLife Syn 5w30 / OCI 7,500 +/-
Purolator PureOne 10241
Redline SL-1 Fuel System Cleaner
________________________________________________
