I am looking for a high temperature dry film lubricant. Preferably a type that is applied by drip or brush, but spray can also be used. I just don't want spray going on things I don't want coated. The operating temp range is 500*F to 1000*F, but most likely it wont see temps above 800*F. Some lubrication is needed at room temp. Some sources say Moly isn't used above 600*F. Silicone and Teflon are out. There use to by some stuff for lubing motorcycle clutch cables. Any recommendations?
