I read on another forum that you need to disconnect the battery after changing out the transmission fluid in your vehicles. I have never heard this to be necessary and I know the internet can be filled with a lot of bovine fecal matter, so I thought I'd ask you guys. Below is the copied and pasted explanation given on the other forum. It sounds legit, but I have never heard about anyone doing it.
Quote:
"The computer reset is required because the transmission learns how much the fluid allows the clutches to slip and compensates for it. Without resetting this it will assume the old fluid characteristics and use pressures/duty cycles based on that which may burn out your clutches quicker."
