I have about 3 quarts of Warren non-detergent, straight 30 motor oil that I grabbed 2 months ago at local stop and rob. I needed some oil for the oil-can to lube my drill bits when drilling aluminum and steel bar stock. It was less than $.89 a quart. I also use it to put a rust proofing coat on tools and what not. Now the store sells some crud called "costal" but at least it has the API starburst and is SL.
Have a laugh..... Dave
What else can I use this stuff for? Oiling door hinges?
