What would be the cross reference oil filter for the 4g15 Mitsubishi 1.5L engine.Please list most popular brands and part numbers.
1995 Eagle Summit ESi
Auto Trans
No AC
It's specified to use the Purolator 14610, Wix 1356, Fram 7317. You could also use a slightly oversized version if you have room for the added width: Purolator 14459, Wix 1334, Fram 3593A.
Thanks alot, very informative....keep up the good work!!!!Just a quick question, I noticed the Motomaster oil filter no#17-1723-6 also has a number listed below it,PH3583A, what is that number for?
Are you sure it didn't say PH3593A? That would be the cross-reference to the Fram part number. That's the slightly wider version of the recommended part # for your Eagle.
