Hi,
I realize who makes each and that these two filters are similar. My question is, "Is there a difference between these two filters as far as oil flow or volume?"
A01 has 8 small holes orbiting the large threaded hole.
A02 has 10 oblong holes orbiting the large threaded hole.
It would "appear" that the A02 can pass a larger volume of oil vs. the A01.
The Accord had the A02 on it from the factory but I have purchased A01 as it seems to be a better quality filter (filtech) compared to the A02 (honeywell/fram).
I do NOT want to starve the engine if there is a oil flow difference between these nearly identical filters. Filter media my have an infuence on oil flow also. Anyone have the oil flow spec's on these two filters? Search on this site revealed lots of info on these filters but no mention of the all important oil flow.
Thanks for your replies!
