Overview Article
Seymour Traditional PHD
Peavey Traditional & Split Handle PDH These are more expensive but is that solely due to lower volume or better construction?
Anyone ever use the split handle PHD? Are they better or should I stick with the traditional?
Is it better to have riveted or bolted?
I'm thinking that 6' hardwood handles will be about right as 6' handles would put the PHD over my head initially but as the hole is dug it would be closer to eye level.
Seymour DG-100 says it uses #2 hardwood handles. What does this mean & is it the de facto standard?
Any other made in USA post hole diggers?
Thanks.
Thanks.
