Originally Posted By: crazycrak
Ok how is Pennzoil HM oil? I havent heard to much about it.
The leak is comming from the rear main seal. Its just barley damp around the dust sheild somtimes you can see a little drip hanging on to the bell housing.
My '97 Dodge Dakota has a small rear main seal leak, like yours. Mine's a BIT faster than yours; it's always got a drip hanging from the bellhousing, and will often leave a spot or two on the ground when parked overnight.
I've had luck using Valvoline MaxLife oil. I've used a lot of Pennzoil products in the past (I use PP in the van), but have never tried the Pennzoil HM for some reason. The Valvoline is typically a dollar cheaper, so that's what I've been using.
If I don't use the MaxLife, the leak on my truck is worse, when I do use it, the leak is gone for the first 1000 miles or so, then slowly re-appears. I'm on a 2k mile OCI interval (due to low miles driven per year), so overall, I don't lose much oil.
I'd suggest either the Pennzoil HM or the Valvoline ML. I think you'll have some success with that, given how slow your leak is.
