getting rid of a website from drop down menu...
I found this on a quick search. Doesn't say which version it's for or if it's the same with all of them.
Quote:
Firefox Quick Tip: How to Delete Items from Address Bar History
For a quick purge of your Browsing History:
Press Ctrl + Shift + Del to launch the Clear Private Data Menu
Check the Browsing History checkbox
Click OK
To delete individual entries in the Address Bar History:
Press the Ctrl + L shortcut to go to the Address Bar
Press backspace to clear the bar
Start typing the first few letters of the item you want to delete
Press the down (and up) arrow keys to cycle through the entries
Press the Delete key to delete the entry
tools>options>privacy
Near the bottom there's a checkbox to 'clear history when firefox closes' and a settings button if you wish to specify exactly what.
Having that checked will make firefox completely erase your tracks each and every time you close it.
it wont be completely deleted.
to completely get rid of it, you will have to mess with REGEDIT.exe. if you know how.
i wont explain it here because it can cause problems if not done well.
google REGEDIT and history
Originally Posted By: George Bynum
use the arrow keys to highlight it
hit delete
yeah, it really is that easy
Yes,it was that easy,thanks!!!
Originally Posted By: bdcardinal
hiding the pronz i see, its alright.
HAH, sounds like someone forgot to put it in "Private Browsing" mode. The private browsing mode is nice, you turn it on and you can surf without creating a new history or saving the cookies, and then when you turn private browsing mode off, it goes back to normal with the previous history and everything in place. So it's like you weren't surfing.
It's a nice feature for when you share a computer and you're doing something like Christmas shopping for the other person. This way everything remains normal and they don't see what you were doing in the history. Though b/c of the more obvious uses for it, many people have termed it "porn mode". But it does have other useful uses (like hiding gift purchases).
Important to note, it only hides it from the browser side, your router and ISP will obviously still have records of everything, and I assume any locally stored DNS entries would also be there
Originally Posted By: sicko
this is a valid point. Thanks sicko!
Originally Posted By: daves66nova
Is it possible to only get rid of one website from the dropdown address bar? xp home FireFox 3.6
I just did this and it worked:
Hit address pulldown so to see sites in pulldown.
Highlight the address you want deleted.
Hit the delete key, it should disappear off the pulldown list.
Works for me ... Firefox 3.0.17
