Part Number: 57502
UPC Number: 765809575028
Principal Application: Ford, Lincoln, Mercury, Mazda (09-10)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.090
Outer Diameter Top: 2.942
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.753 2.397 0.250
vs. the modular fitler
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-10), Mazda (00-09), Cadillac STS-V, XLR-V (06-09)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.668
By-Pass Valve Setting-PSI: 16
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Gasket Diameters
Attached 2.834 2.462 0.200
Skinnier and lower bypass setting seem to be the distinctions.
