FL500S
ctc
VA
You can't really see in this picture but in the magazine (C&D) it is larger and readable. The filter on the new 5.0 for the Mustang is a MC FL500S. Is this a new one? I haven't seen it before.
It is used on the 2009 Escape with the new/modified 240 hp 3.0 V6, and I assume, on the 2010 Fusions with the same powerplant. Its shorter than a FL400S.
Right now they are dealer only (not available at Wal-Mart), and are about 12 bucks a piece...I hope that will change with time as these new engines enter the market..
Part Number: 57502
UPC Number: 765809575028
Principal Application: Ford, Lincoln, Mercury, Mazda (09-10)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.090
Outer Diameter Top: 2.942
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.753 2.397 0.250
vs. the modular fitler
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-10), Mazda (00-09), Cadillac STS-V, XLR-V (06-09)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.668
By-Pass Valve Setting-PSI: 16
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Gasket Diameters
Attached 2.834 2.462 0.200
Skinnier and lower bypass setting seem to be the distinctions.
I could have sworn I saw the FL-500S on the shelf at my local WM.
I know I did, it was a recent addition though. I think it costs $4.97 vs the FL820S costing $3.97
Whimsey
