I have a 2004 model Specialized HardRock Sport.
About a year ago, I discovered that the original chain was very worn, So, I replaced the rear cassette with a SRAM PG-850 and the chain with a SRAM PC890. Ever since then, I could feel the chain "skip" if I pedaled with moderate to heavy pressure. Not knowing what the problem was, I lived with the problem for the past year and in doing so, accumulated a few hundred miles on the bike.
Recently, I noticed that my front chain rings are getting very worn, so I need to replace those. It appears that my chain rings are riveted together, so I'll need to replace the entire crankset. Currently, I have a Truvativ ISO-Flow crankset, 42/32/22 cr-mo chain rings and a Truvativ 68X113 square-taper bottom bracket-- all of which are original.
So, here are some questions I have:
1) Currently I have a square-taper bottom bracket. Can I switch to a Octalink type bottom bracket? I ask because there are more crankset choices if I switch to an Octalink type bottom bracket.
2) If I decide to stay with a square-taper compatible crankset, should I replace my bottom bracket when I install the new crankset? I don't have any issues with the bottom bracket right now, though it is nearly six years old and probably has 500 miles on it.
3) So, if I stay with a square-taper setup, I plan to buy a Shimano Alivio FC-M410 crankset and a Shimano UN-54 bottom bracket. Or, if I go to a octalink setup, I am going with a Shimano Deore FCM-442 crankset and a Shimano ES-51 bottom bracket. What do you guys think of those choices?
Thanks!
Thanks!
